0 Members and 1 Guest are viewing this topic. Read 1868 times.
I would just point out that there is scientific evidence of 'lateralization' in the perception of bass frequencies, particularly with acoustic or orchestral music. I'm a bit hazy on the particulars, but it comes down to the idea that the listener can get a more spacious or realistic sound if bass sources are arranged in stereo. It's not the same as 'localization', and is more subtle, but it may be worth trying stereo sub array if two subs are being used. And since you have L/R outs, it would be an easy experiment. AJinFla can tell you more if he sees this and is so inclined, as he's the one who hipped me to the concept, and has looked at the research.
Thank you gentlemen, for all your expertise. You're a great resource for us beginners!
Since I’m starting to get into subs myself, i started a thread a few months back. One person suggested to use the preAmp outas you describe, but use “Splitting” or bifurcated RCA cables instead.Such that there is only one termination on the RCA cable on the Pre end. But 2 terminations on the RCA cable that goes to the sub, into the R and L channel. I’m not sure why this may be better, other than higher voltage or gain.
