*** SOLD *** - Transcendent Sound Balanced Power Supply
0 Members and 1 Guest are viewing this topic. Read 1567 times.
LostInPA
Transcendent Sound “Balanced Power Supply” which is a 1
kva balanced power transformer plus a few small capacitors in an aluminum
enclosure.  Included is the as supplies
power strip.  Assembly manual
included.  Found Packaging.
$225.00 plus shipping from ZIP 18661
« Last Edit: 24 Mar 2018, 05:31 pm by LostInPA »
Re: For Sale - Transcendent Sound Balanced Power Supply
« Reply #1 on: 12 Feb 2018, 07:38 pm »
This PS is suited to feed what equip?
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« Reply #2 on: 12 Feb 2018, 07:54 pm »
More of a power conditioner than power supply.  Six AC outlets for equipment.  (I'm not the seller)
« Reply #3 on: 12 Feb 2018, 08:05 pm »
These 6 holes are not connected inside.
SMT are just 1 output in the center or it apper to be connected inside;
pstrisik
« Reply #4 on: 13 Feb 2018, 03:53 am »
There is one outlet on the unit, but he is not showing the power strip with six outlets on it that plugs into the main box.  The company emphasizes the flexibility of placement to justify that approach.  Not a bad approach, IMO.  Unless you believe the extra connection is a negative.  I don't.  And for the asking price, it's a low cost way to get some clean power if you think the main design is a good one (I don't know myself).  Even a basic Panamax power conditioner costs more than $225.
« Reply #5 on: 13 Feb 2018, 04:30 am »
Ah now it make sense, thanks a lot :thumb:
LostInPA
« Reply #6 on: 14 Feb 2018, 08:10 pm »
From the manufacturer, product details and general balanced power information:  http://www.transcendentsound.com/Transcendent_Sound_Power_Supply.html
More detailed balanced power information:
http://www.equitech.com/
Safety information:
Almost all audio equipment have single pole power switches, to break the 120 volt input power.   Balanced Power puts 60 volts on each of the two power legs, therefore turning off the single pole power switch leaves 60 volts still unswitched.   In general practical use, this is of minimal consideration.   If, however, you are one of those people who pokes and prods inside your equipment with the power cord still connected, you will be putting yourself at risk.   In all cases, working inside electronics has risks; even when a unit is unpowered, capacitors hold dangerous levels of power.   Be in control of your own safety.
LostInPA
Re: *** SOLD *** - Transcendent Sound Balanced Power Supply
« Reply #7 on: 24 Mar 2018, 05:32 pm »
*** SOLD ***
