computer not starting
0 Members and 1 Guest are viewing this topic. Read 7507 times.
soundofrockets
« on: 4 Feb 2018, 06:51 am »
i got this refurbished HP from tiger direct - lease return about 2 years ago.  Never really got a chance to hook up.  tried today and it keep saying to restore and when i check ok it gives me "error 1" and the whole process starts again.  Not sure if tiger direct will give me any tech support.  all the boxes and paper work are somewhere in the house and not readily available.  any suggestions ?
TIA
Re: computer not starting
« Reply #1 on: 4 Feb 2018, 07:05 am »
What is the OS?
If no valuable file is in the HD I could reinstall the OS to a free W10 if the chipset allow or reinstall a W-XP if a smaller OS is suited to an slower processor.
soundofrockets
« Reply #2 on: 4 Feb 2018, 07:13 am »
it came with windows 7 professional 64 bit
HP Compaq 8200 Elite Desktop PC - Intel Core i5-2400 3.10GHz, 8GB DDR3 Memory, 1TB HDD, DVDRW, Windows 7 Professional 64-bit
this is the info i have from my invoice.
cannot believe this was in 11/2015!!!
« Reply #3 on: 4 Feb 2018, 07:33 am »
A nice machine, any more detail on the error?
soundofrockets
« Reply #4 on: 4 Feb 2018, 07:36 am »
it simply says "error 1"  while trying to restore.  and when i close that window - the whole process starts again and ends with the same error.
i don't get the option to start with windows 7.
« Reply #5 on: 4 Feb 2018, 07:37 am »
Symptoms of Code 1 (Error 1)
    “Code 1” appears and crashes the active program window.
    “This device is not configured correctly.” is displayed when attaching a new hardware device to your computer.
    Your PC frequently crashes with Error 1 when trying to use the same hardware device.
    Windows runs sluggishly and responds slowly to mouse or keyboard input.
    Your computer periodically “freezes” for a few seconds at a time.
These 1 error messages can appear during program installation, while a Microsoft Corporation-related software program (eg. Windows Operating System) is running, during Windows startup or shutdown, or even during the installation of the Windows operating system. Keeping track of when and where your Code 1 error occurs is a critical piece of information in troubleshooting the problem.
Causes of Code 1 (Error 1)
    Incorrectly configured, old, or corrupted device drivers. (very common)
    Corruption in Windows registry from a recent software change (install or uninstall).
    Virus or malware infection that has corrupted Windows system files or related drivers.
    Driver conflict after installing new hardware.
    Faulty hardware.
Device Manager Errors such as “Code 1” can be caused by a variety of factors, so it is important that you troubleshoot each of the possible causes to prevent it from recurring.
« Reply #6 on: 4 Feb 2018, 07:40 am »
soundofrockets
« Reply #7 on: 4 Feb 2018, 07:44 am »
i don't have the disc - not sure if the computer actually with the disc or the OS pre-installed.
« Reply #8 on: 4 Feb 2018, 07:49 am »
It should have the basic system to allow further OS instalment.
soundofrockets
« Reply #9 on: 4 Feb 2018, 07:51 am »
pardon my IT naivety - where do i start.
connect the monitor, mouse, keyboard, Ethernet cable and power up !
what comes next?
« Reply #10 on: 4 Feb 2018, 07:55 am »
If the OS is not installed after the power-on the basic system will allow you begin the OS installation, of course you need to have the OS in DVD media on hand.
soundofrockets
« Reply #11 on: 4 Feb 2018, 07:58 am »
i am not sure if the computer actually came with the CD/DVD for the OS.   :scratch:
« Reply #12 on: 4 Feb 2018, 08:03 am »
So You may need a DVD driver mounting in this case.
The DVD driver is not opening the drawer?
soundofrockets
« Reply #13 on: 4 Feb 2018, 08:06 am »
i am not sure what you are asking  :scratch:
« Reply #14 on: 4 Feb 2018, 08:07 am »
The DVD is not opening the drawer?
soundofrockets
« Reply #15 on: 4 Feb 2018, 08:10 am »
do you mean the dvd media tray on the computer next to the power button?
« Reply #16 on: 4 Feb 2018, 08:11 am »
Correct.
If it dont have DVD you may install the OS from an Pen driver.
soundofrockets
« Reply #17 on: 4 Feb 2018, 08:32 am »
ok.  but i will need to download something on the pen drive - right.  what do i need to download and from where ?
WGH
« Reply #18 on: 4 Feb 2018, 04:40 pm »
System restore error 1
https://answers.microsoft.com/en-us/windows/forum/all/system-restore-error-1/04dea3b2-0626-4b51-8b0f-78213743287f?auth=1
First try to restore in Safe Mode
How to Start Windows 7 in Safe Mode
https://www.lifewire.com/how-to-start-windows-7-in-safe-mode-2624540
Second, forgetabout Windows 7, I would go straight to 10, it is faster and more stable than 7 ever was. If 7 is installed but not booting (starting) then go to the Windows 10 Media Creation Tool website to download the Windows 10 .iso and create a bootable DVD or thumbdrive. Of course you will have to use a working computer to do this.
Insert the new DVD or thumb drive in the dead computer and restart, you may have to change the booting order in the BIOS ( hit Delete button during power up, you have to be quick)
You should qualify for a free Windows 10 upgrade, if it doesn't work what do you have to lose, it's broken already.
Note: If an official Windows 7 is installed there should be a sticker somewhere on or inside the computer (or on your receipt) with the Windows 7 25-character serial number.
Create installation media for Windows
https://support.microsoft.com/en-us/help/15088/windows-create-installation-media
Download Windows 10 - use the "Download Tool Now" button
https://www.microsoft.com/en-us/software-download/windows10
soundofrockets
« Reply #19 on: 4 Feb 2018, 08:26 pm »
Thanks FRM and WGH.
I will first attempt to restore in safe mode.  If successful - great.
Then look for windows10 upgrade.
Computer case does have a sticker on the side with some numbers- hope that is the original 25 digits that I need.
