0 Members and 1 Guest are viewing this topic. Read 4122 times.
Wow very beautiful amp Congratulations GUF, what is the input and rect tubes?
12j5 and a 5y4 open to suggestions on replacements.and Oliver said "Parts quality is quite good but there is gains in upgrading certain capacitor/resistor output transformer or switching to transformer coupling/decoupling" I'm excited to play around with some upgrades.
So I hooked a DHT 4p1l pre up and it provided a little bit of needed volume. Is that gain? But then I felt it lost some of the magic.
Guf,I can see in a different thread that your main system consists of Omega speakers along with Gr Research/Rythmik subwoofer. Have you given some thought to the use of a high-pass to reduce the load on the amplifier? Most likely it could play a little louder considering the Korneff is a low gain design and you prefer not to use an active preamp...You can search the gr research forum for more info if you'd like (inline crossover input impedance).Gorgeous amp by the way!
