0 Members and 1 Guest are viewing this topic. Read 7201 times.
I have been listening to lots of classical on my Beyerdynamic Amiron. Excellent detail and 'speed' but smooth too. They are half the price of the T1 and I'm not sure the extra expense is justified (I have heard both).From the models you mentioned initially, I gather you are looking at full size 'phones, but you don't indicate a preference as to open vs closed (if any) or a budget.IEM's are comfortable for me with the right tips- I use memory foam with my Etymotics and custom silicones ($$) with my Shures.
I am a classical music fanatic and the Etymotic ER4 or ER3 are the way to go, especially if you use the aftermarket Comply tips with them. The ety’s provide good comfort, excellent isolation and a perfect window onto the recording.
I am a classical music fanatic and the Etymotic ER4 or ER3 are the way to go, especially if you use the aftermarket Comply tips with them. The Ety’s provide good comfort, excellent isolation and a perfect window onto the recording.
+1 on the Etymotics. I have hf5's and like them a lot. The new ER3's are somewhat similar but have the large advantage of a detachable cable (the cable being the most likely failure point). Both ER3 and ER4 (new version) come in two 'voicings', one as ruler-flat as they can make it and one with a slight bass boost. +1 on the Comply foam tips too, for me they are better than any of the OEM Ety tips (YMMV).My Shure SE535's are more detailed than the Ety's but not as scrupulously neutral, tending a bit towards the 'warm' side.
Some excellent recommendations being made here. I think I would need an external amp for the AKG or Amiron. The KANN does have more ability to drive headphones than most DAPs. For IEMs, my limited experience to date leans towards armature vice dynamic drivers. Having said that, would like to hear the ER4.Anyone listened to the Meze 99 Classics? They get a lot of good ink, and replacement parts are available should the need arise. Unrelated question: Would the headphone amp in a Mac D150 be sufficient to drive the Amiron?
Ety ER3 and ER4 both use armature drives, not dynamic. That's why I like them so much. And they are physically small, so they're a lot more comfortable to wear than other IEMs.
