0 Members and 1 Guest are viewing this topic. Read 2704 times.
Hey guys, Given how good these sound even with their crappy amplifiers, I'd like to investigate replacing the onboard dsp / class-d amplification with a minidsp + a good 4-channel amp (for a pair of the JBLs).I've done something similar before....but I'm wondering what functions the onboard JBL dsp can't (if any) be duplicated with a software solution like Room EQ Wizard with individual driver measurement and correction?I mean, honestly, the speakers sound great as is....but I love trying to make stuff "better".-Jim
Good luck. Without an anechoic chamber and discrete detailed polars in both the horizontal, vertical and oblique axes or a polar map, you are shooting in the dark. I really think REW (which I use heavily) is perfect for in room measurements below 300 Hz (without smoothing) and only fine for confirmatory measurements above 300Hz in room with 1/6th-1/12th octave smoothing to verify that the loudspeaker performs as it should. But to use it from the ground up to design a loudspeaker that performs well from a polar standpoint above 300Hz? Sorry, even with gating, etc...I would be afraid that my data isn't real. Put the loudspeaker high up hanging upside down in a gymnasium and now we are getting somewhere. Or build an anechoic chamber. But then oops, I forgot, you need to be an audio engineer, with an EE at least for starters. If you are able to download the DSP file and then input that into a well designed third party DSP with multiple separate amplifiers, okay, then we are getting somewhere. Others have tried, but they have failed (do a google search).Perspective: Why not get a JBL 705i or 708i with a BSS processor and do that instead? Or just get the 705p/708p and be done. The drivers and waveguide are much improved than the 3 series. Frankly, I'm shocked with how good the LSR305 polar measurements are and the pair matching they provide at that price. Like you said, the speakers (LSR305) sound great as it is. Best,Anand.
Do you not believe in software solutions like Dirac and Audiolense then? I mean of course I'd rather have 708i 's. But I'd also rather have have jbl 4367's, too.But those are obviously many multiples the price of the 308s so not terribly relevant.-Jim
I'm really liking the 708P's in my home as much as I did in CA.
