SS into Quad ESL-57
0 Members and 1 Guest are viewing this topic. Read 1408 times.
Scroof Neachy
  • I like to smell stuff
SS into Quad ESL-57
« on: 19 Jan 2018, 03:17 pm »
I recall that the venerable NAD 3020 was stable into a Quad ESL-57, while many SS amps struggled with its wild and wacky impedance curve.
Has anyone used a NAD BEE series integrated amp with this speaker? Or what about the hybrid D3020? Some say class D is not a good fit, but others say it’s fine. I guess it depends on the circuit.
Don_S
Re: SS into Quad ESL-57
« Reply #1 on: 19 Jan 2018, 03:52 pm »
I have a C356BEE that worked great on PSB Imagine Minis and KEF LS50s.  Failed almost immediately when put on Quad ESL-2805s. Integrated is in the shop now.
Bad timing or bad pairing?  You decide but I would not recommend the combo.
rollo
  • Rollo Audio Consulting -
« Reply #2 on: 19 Jan 2018, 05:09 pm »
   NAD should be OK, does no harm. We have preferred Peachtree and better yet Arion HS500 hybrid class "D"mono blocks, just awesome.
charles
Scroof Neachy
« Reply #3 on: 19 Jan 2018, 10:42 pm »
Those amps are way too pricey. I just need a stopgap solution while I’m gathering parts for some mono tube amps. I just want to make sure that no damage will be caused to the amp, and more importantly, the speakers!
Manolo
  • Consulting Structural Engineer
« Reply #4 on: 30 Jan 2018, 11:59 am »
First Watt class A amps. F4 if you have a high gain preamp., otherwise go for one of the others. Magical combination!
macrojack
« Reply #5 on: 30 Jan 2018, 01:08 pm »
If you ask nicely, some other AC member may offer to loan a tube amp temporarily while you finish your amp build. I've seen it happen. Would probably only cost you round trip shipping.
Pose your request right here in this thread.
