0 Members and 1 Guest are viewing this topic. Read 10420 times.
I also have to disagree with JLM's assessment of Decware enthusists being bass-heads. It just doesn't ring true based on folks posting on the Decware forums and the owners I know personally.
I own the Decware Zen Head for portable use. It has internal jumpers to match your headphone Ohm load. One of the best portable amp on the market.
Deckert has no formal electronics background, so his 'designs' are off the wall and done by trial and error.
It double as pre-amp?
Not designed to be used as a preamp.http://www.decware.com/newsite/zenhead.htm
It could boost the sales, I suppose it would need a bigger battery though.
I have heard their amps and speakers enough to pretty much disagree with everything JLM wrote above about Decware since I've been familiar with them (probably 15 years or more).
I suppose no one commercial speaker have the bass taylored to a small SE tube amp, it usually is modeled to powerful SS amps which has more than 50W and hi damping factor.
