0 Members and 1 Guest are viewing this topic. Read 6641 times.
In nearly 50 years I have yet to find a tweak (defined as a 'cheap' add-on) that works. Recently I converted my entire system to balanced gear/cable to lower the noise level and avoid all the stupid cable voodoo.When it comes to speaker cables get good connectors (suggest clamping banana) and run 14 - 16 gauge wire (no need for fancy metallurgy). Refer to:http://www.audioholics.com/gadget-reviews/speaker-cable-and-audio-interconnects
Herbies Gliders work great under standard VSA spikes on wood suspended floor, plus he has a set to pucks specifically designed to go between the upper and bass modules for VR4 and VR5 that made good difference as well.
Not to start yet another cable war but yes there is a sonic difference in cables.
... Perhaps your hearing is causing you a problem or that you might have an advanced stage of tendinitis.
All I can say is that I am very pleased with the By-Wire's and it is the way to go for sure.
..no offense but don’t have Audioholics high on my credibility list. Not to start yet another cable war but yes there is a sonic difference in cables. Call me crazy but I and other fellow crazies have confirmed it more than once. And for the record, I actually happen to have EE degree thanks to Purdue University...so there
