0 Members and 1 Guest are viewing this topic. Read 2338 times.
Many many kudos for the Parks Audio Budgie!! Love mine
Recommendations for a cheap and cheerful tube phono pre amp? Go! thanks
AVA has a phono preamp, no tubes but $499 will get you excellent sound.http://avahifi.com/products/for-vinyl-lovers/vision-riaa-phono-preamplifierJim Hagerman's phono preamps have extremely well designed circuits. I built an upgraded Cornet2 from a kit and love it. The pre-assembled Cornet3 is basically the same with two 12AX7's and a 12AU7 tube but without the massive transformer and rectifier tube. $459.00 and you could always make a nicer case later or spray paint it Ferrari red. https://hagerman-audio-labs.myshopify.com/collections/phono-preampsSave some money and eliminate the tubes with Bugle2 kit for $49 (circuit board only) or an assembled Bugle3 for $239.I had a Bottlehead phono preamp before the Cornet2 and the comparison between the two did not go well for the Bottlehead, the Cornet2 was exponentially better in every department.
