Infraflex tientien (Etienne) test + MTM Visaton BG 20 / compression 1" horn RCF
0 Members and 1 Guest are viewing this topic. Read 202 times.
hello all,   :D
Happy New Year everyone !
Here is my new system test, I am very happy with the result, finally an OB that actually produces serious, fixed membrane system on the outside, glued.
it is a polystyrene plate 20 mm thick 1 m², the speaker acts as a piston on the center of the plate.
I replaced the spider by a more flexible and limited model Xmax to 10 mm (fs= 23 Hz), the junction between the speaker and the polystyrene plate is made with a rigid cardboard tube.
cheap system and easy to manufacture.
some images and a recorded soundtrack of the system with a pair of micro C2 Berhinger.  :D
