The nuprime remote. A disaster.
0 Members and 1 Guest are viewing this topic. Read 297 times.
jojo
« on: 31 Dec 2017, 09:28 pm »
Trying to change battery. No way. The whole remote falls appart.
Doing a great product and fails to make a remote! Why? :icon_twisted:
No manual.
 Five different screws.
Send me a manual. Please!!
IDA - 16
Samac
Re: The nuprime remote. A disaster.
« Reply #1 on: 31 Dec 2017, 10:58 pm »
The metal wand remote that came with my IDA-16 has four(4) screws on the back; three(3) hex head and one(1) Phillips head.
To insert/change batteries loosen/remove the Phillips head screw, slide battery tray out and insert batteries, slide battery tray back in and insert/tighten Phillips head screw. Enjoy some music. :thumb:
Scott
John Casler
« Reply #2 on: 31 Dec 2017, 11:05 pm »
No manual.
IDA - 16
Hi Jojo,
Sorry to hear of the remote issue.
You need only remove a "single" screw (the one with the Philips head) to change batteries in the IDA-16 remote.
Do not remove any of the "hex-head" screws.
Once the Philips Head screw is removed, you may need to shake the remote a bit to get the battery compartment to slide out.
Once you have changed the battery take care to slide it back in so that the hexoganal portion slides "into" the remote.  This may take a couple tries.
IDA-16 MANUAL is HERE.
