Audio/Video Gear and Systems
Cheap and Cheerful HiFi
Letitroll98
line level or RCA A/B switch?
0 Members and 1 Guest are viewing this topic. Read 1549 times.
flavo
31 Dec 2017, 02:54 am »
I'm trying to hook up 2 subwoofers, a left and a right, to both of my amps. My home theater 5.1 and my my mono block 2 channel set up.
In order to do this easily and safely, I assume I need some kind of switcher? Up until now I've just been unplugging one set of RCAs and switching them for the appropriate amp.
Is this what I need? Do you have other suggestions? Do these both do the same thing? Should I be looking for a better quality switch? Maybe I can even build one??
Also I tried posting in the "path of least resistance" but it wasn't allowing me for some reason.
Thanks folks.
https://www.amazon.com/Stereo-Switch-Splitter-Adapter-Toggle/dp/B01N4B94LZ/ref=pd_sbs_23_8?_encoding=UTF8&pd_rd_i=B01N4B94LZ&pd_rd_r=ZNEZHYM4P4MSZ8RZJ6NH&pd_rd_w=f2ZMo&pd_rd_wg=YLNQN&psc=1&refRID=ZNEZHYM4P4MSZ8RZJ6NH
https://www.amazon.com/dp/B00TL1QH4C/ref=sspa_dk_detail_0?psc=1
Edit: Found this too.
http://www.diyaudioblog.com/2012/06/custom-rca-switch-box-for-audio.html
Speedskater
Kevin
Re: line level or RCA A/B switch?
31 Dec 2017, 01:51 pm »
Heck, even Radio Shack made RCA input selector switch boxes. Yes they are labeled input, but nobody will tell if you use them for outputs.
Phil A
Reply #2 on:
31 Dec 2017, 03:08 pm »
Stores use brands like -
https://www.pacrad.com/calrad-40-649-three-position-rca-video-stereo-audio-switch.html
or
https://www.audioauthority.com/product_details/1154A1
Years back when Circuit City was going out of business they had these huge plastic bins full of things. I asked how much and they said $25/bin, including the bin and contents. So I picked up one. It had Audio Authority and Calrad distribution switches in it they used to distribute audio (e.g. from CD/DVD players) or video. I used one for a bit in the old house and gave away some of the cables.
pinkfloyd4ever
Reply #3 on:
1 Jan 2018, 05:20 pm »
So you need two 2-channel inputs and one 2-channel output, correct?
How about the Schiit Sys?
http://www.schiit.com/products/sys
Letitroll98
