Dodd preamp remote
0 Members and 1 Guest are viewing this topic. Read 1021 times.
skalos
Dodd preamp remote
« on: 28 Dec 2017, 01:12 am »
Hi All,
I think my luck will be better here in Danny's circle than any other.
I have a Dodd battery powered pre-amp which has a remote for volume only.  When I opened it to change the battery, I realized that the red lead from the battery to the board has separated from the board.  I don't know where to re-solder this lead.
Does anyone have a circuit design or photo of the inside of one of these remotes that might explain where I need to reconnect the lead?
Any help would be appreciated, thanks.
Steven
HAL
Re: Dodd preamp remote
« Reply #1 on: 28 Dec 2017, 02:11 am »
I have Gary's remote for my buffer.
Post an internal picture of the remote and will point out where the battery + lead goes on the PC Board.
skalos
« Reply #2 on: 29 Dec 2017, 03:30 am »
Here is the photo. The red lead is not connected.
JerryM
  • Where's The Bar?
« Reply #3 on: 29 Dec 2017, 03:37 am »
This one might be easier to see:
 :thumb:
HAL
« Reply #4 on: 29 Dec 2017, 03:53 am »
If you turn it vertical you will see an extra solder pad beside the negative connection.  That is the red positive wire for the battery.
ZAKski288
« Reply #5 on: 29 Dec 2017, 03:55 am »
Here is a picture I just found, it might help. Hal just posted as I was typing. Good Luck Zak
skalos
« Reply #6 on: 29 Dec 2017, 06:59 pm »
Hi all again,
I didn't notice that solder point on mine.  The black wire is probably hiding it.  I will look for it later today.
Thank you everyone.
HAPPY NEW YEAR
