about DAC-9 aes input
0 Members and 1 Guest are viewing this topic. Read 176 times.
« on: 27 Dec 2017, 03:45 pm »
If I use AES between CDP and DAC-9 , is it better than coax or optical ?
I don't have aes cable and usually use coax . So is it worth to try AES ?
Re: about DAC-9 aes input
« Reply #1 on: 27 Dec 2017, 04:24 pm »
usually, but not always (in audio it is always like this!!!!!)
AES should be better
i have tested on different Dac's both plastic optical (glass-fiber Lifatec cable) and AES and i like AES more
Wadia connection ranking is:
1) glass optical (Wadia proprietary)
2) AES/EBU (now AES3) using XLR connector
3) Coax using BNC connector
4) Coax using RCA connector
5) Toslink plastic optical
unless you have a real first-class BNC output, AES is easier, it is the pro audio standard , plenty of very good and inexpensive cables around
