The Music Circle
Recommend some Tidal Playlists
0 Members and 1 Guest are viewing this topic. Read 766 times.
Larry Dickman
Restricted
26 Dec 2017, 10:29 pm »
I wish Tidal had Stations like Pandora. The "Artist Radio" feature on Tidal is a mixed bag and I don't know if those playlists ever change. The "Radio" based on genre is quite limited--for example all forms of Rock, Jazz, or Classical are lumped together without distinction (such as "Classic Rock" or "Bossa Nova" or "Renaissance") Can anyone recommend Tidal playlists?
I created the following 70s and 80s playlists based on year-end Billboard Hot 100 and from
http://www.playlistresearch.com
1970
https://listen.tidal.com/playlist/39dc0824-44ce-47e6-b179-de1da3032ccf
1971
https://listen.tidal.com/playlist/f825772a-b9eb-4c6a-992f-2019c3a44659
1972
https://listen.tidal.com/playlist/04624146-6d33-47b1-a9d9-eb0482e8dee4
1973
https://listen.tidal.com/playlist/c8c2a2d2-95fe-474a-a069-0f7bc293aef5
1974
https://listen.tidal.com/playlist/e4f5ee5f-45ca-490d-bf22-94e7a49ec66e
1980
https://listen.tidal.com/playlist/65f559f5-2bca-447c-a540-15b66d79f313
1981
https://listen.tidal.com/playlist/f4bb0e84-0527-4a23-b5e2-31bd2c0d339a
1982
https://listen.tidal.com/playlist/a2c1c9fd-022e-4323-9cd7-d2ee58abc2fc
1983
https://listen.tidal.com/playlist/76c45779-c5be-470c-badb-e94eb3214ffe
1984
https://listen.tidal.com/playlist/5261bce2-a567-44b9-b6e0-7de0390e792e
1985
https://listen.tidal.com/playlist/417d1df3-e30c-4a15-a2a0-c00d69765479
Above Combined
1970s Hits
https://listen.tidal.com/playlist/4c01620f-2e0a-4cd0-bffa-ac380572a2f6
1980s Hits
https://listen.tidal.com/playlist/d54f3a50-e21f-4ab1-9222-15e03aa4644d
Playlist based on Time/Life "Flower Power" aka "Woodstock"
https://listen.tidal.com/playlist/de8f73e5-2f5c-48b4-9be3-fc58592fd47b
1970s Soul Hits
https://listen.tidal.com/playlist/39238530-0f1d-412d-a7e5-34dc3547cde7
90s Mix
https://listen.tidal.com/playlist/f063834f-c942-4d2a-b4c4-3fe3ab6fe079
mr_bill
'let's go Rangers'
Re: Recommend some Tidal Playlists
26 Dec 2017, 11:11 pm »
Thank you for sharing!!
I just added 70’s 80’s and Woodstock playlists
The Music Circle
