0 Members and 1 Guest are viewing this topic. Read 3070 times.
Not a lot of good open choices in the low-mid price categories. The Philips SHP9500 is one, and maybe a Massdrop Sennheiser is all I remember.
I mirror dbcooper. I don’t like closed over ear phones. I currently only use iems though. Silicone or foam tips depending on what I want. Silicone is way easier to remove and replace tomtalk to someone. Foam does a better job for isolation and bass for my ears.
I understand the difference (sort of), but witch do you prefer? Sorry if this has been discussed before, I couldn't find any threads.Thanks,eric
Or custom tips (although they're really pricey). As an owner of three pairs of IEMs, two of which are multi-driver BA, however, I'm unaware of any 'open' ones- if it seals the ear canal, it's by definition 'closed', is it not?
When I was a newbie I preferred open headphones because of the hype and the extra airiness and soundstage open headphones come with. As I got more into it this hobby, I prefer closed headphones. To me sound is more intimate, bass is better and imaging is accurate. Soundstage might be a little better on the open headphones, but closed headphones have much more advantage.
Anyone heard, heard of, or have an opinion of the $50 Koss Porta Pro open air headphones?Several of AC recommendations for the budget minded, have been in production for decades, and seem to be quite popular.
