0 Members and 1 Guest are viewing this topic. Read 5075 times.
What is a Din rail breaker?
anyone have any other recommendation?
They are single pole breakers, 1-15 amp and 1-20amp. It seems logical that if the wire makes a difference than the breakers would also. I use din breakers, both A/C and D/C all the time in my solar installs and they meet all the codes. I'm just looking for the highest quality I can find.
In Europe, Schnneider residual current Super immune circuit breaker is a very good idea if you have a dedicated line to audio equipment => additional protection in front the harmonics at mains in polluted environments and networks.Why?The electricity network is getting dirtier every day. The widespread use of cheap SMPS, cheap electrical motors, air conditioners (they add DC at mains too).... usually made in East Asia (China). And bad electrical installations in elevators, and...https://www.schneider-electric.com/en/search/inmmunizedhttps://www.schneider-electric.com/en/search/Super+immune
I wrote days ago:Re: Icepower 1200AS amp. Class D like you've never heard beforehttp://www.audiocircle.com/index.php?topic=153645.msg1647460#msg1647460
I think the best approach would be a old style screw in fuse or cartridge style fuse panel. The parts that matter are all no magnetic.
I have dedicated circuits for my system, I had the sub panel and breakers cryoed but I would like to upgrade to a higher quality ac breaker, I'd prefer a din rail breaker, I found some made by Schneider Electric that look ok, anyone have any other recommendation? Thanks, Mike
I'm using Sq D QOU DIN rail breakers in an aluminum box made for solar. Eliminates the buss.
