0 Members and 1 Guest are viewing this topic. Read 11535 times.
Keep it simple -- no remote because it significantly drives up cost if done right and if a good quality remote is included (not that plastic crap). Two inputs, two outputs, one of each is balanced.$799 price point. At this price, if the preamp blows your customer away, he'll be much more likely to purchase the Cherry amps shortly thereafter.
couldn't disagree with you more about the remote - in this day and age not having a remote - is like not having a cell phone
No, it's worse than that. I can live without a cell phone, been doing that for over 10 years now. But no remote is a deal breaker. I really don't want an integrated DAC, and it must have at least 2 pairs of single ended inputs and 1 pair of single ended outputs or it's a no go for me.
use an Apple remote.
Two analog inputs, maybe three. one balanced, one not. Two outputs same thing.No Dac.Volume control is a MUST! Not having one is living in the past. I put it in the same category as not having a TV remote. Volume and balance control on the remote.Make the case large enough that you have room for the connectors.an additional feature might be an HT bypass.$2000.00 or less if realistic?
How important is the "balance control" part of the remote? That adds a level of difficulty....
...not all songs are in balance and I notice it. They sound better to me if tweaked a little one way or the other depending on the song.
Can you point to a few specific recordings where you found the balance is out?
This question has been bugging me, what would be "class D" about a preamp? I can understand Digital Amplifier Company building a preamp, just not sure what advantage there would be in sending a low level signal through class D.
Time to address the elephant in the room.... It's a preamp, probably analog and digital input. Not Class-D. The amps, if integrated, like the Stereo Maraschino, would be Class-D, however.This device is almost 100% sure to have an FPGA running the show.Regarding "direct digital" amps (PCM -> PWM, etc.). Been there, done that. The price goes way up (to facilitate super fancy components required for great audio performance with that topology), or the performance (measured audio wise) goes down.Thanks as always (:
So no hope for a HT bypass option? Also, a spdif output? I'm really enjoying a pair of the in line Masachino's I picked up this month. They are really amazing amps.
