mac mini HDMI out to Holo Audio Spring DAC
0 Members and 1 Guest are viewing this topic. Read 2011 times.
dcktr
« on: 9 Dec 2017, 05:38 am »
Hello,
I will be getting a Holo Audio Spring DAC in the very near future. Currently I am using USB output from my mid 2011 mini via USB to my W4S DAC.
The Holo Spring has HDMI input. I run the mini headless via team viewer, so my HDMI input is open. According to the manufacturer, the Holo Spring has best results via HDMi.
Does the mini output the same audio via HDMI as it does from HDMI?
Ron
mresseguie
Re: mac mini HDMI out to Holo Audio Spring DAC
« Reply #1 on: 9 Dec 2017, 06:07 am »
Does the mini output the same audio via HDMI as it does from HDMI?:scratch:
Do you mean "Does the mini output the same audio via HDMI as it does from USB?"?
bavmike
« Reply #2 on: 9 Dec 2017, 06:34 am »
No it won't work. The HDMI cable is used for I2S LVDS over HDMI. Completely different than normal HDMI. They just use the same cable.
dcktr
« Reply #3 on: 9 Dec 2017, 07:23 am »
Should have done more research before I asked the question. I would need a usb to I2s converter
Nick77
« Reply #4 on: 9 Dec 2017, 01:45 pm »
Using the i2S connection does kick things up a few notches.
https://www.computeraudiophile.com/forums/topic/29553-my-very-mini-review-of-the-singxer-su-1-ddc/
