0 Members and 1 Guest are viewing this topic. Read 10587 times.
I like the fact that I don’t ever have to wait for these amps to warm up. They are so energy efficient I leave them on 24/7. Waiting for an amp to warm up is now a thing of the past. If I only want to listen to one song, the system is up and ready to roll.
Wind Chaser, Do you mind if I ask ,what are using for your pre-amp .. Were you using the same pre-amp with you tube amp.??
I put my VAC PA 100/100 up for sale as soon as I heard my first DAC amp, a big 'ol Cherry PLus. It was obvious how much information simply wasn't coming out of the tube amp compared to the DAC, which had such vastly superior resolution top to bottom. Especially bottom. Yeah...the bottom of those big transformers...The new generation Maraschino is quite a bit better, though, with greater refinement up top and a tighter but not so stump-pulley bass as the old amps.I never turn mine off and the sleep function works perfectly. The first click of the preamp and they both jump to life and as Wind said they are off and running immediately. It's kinda weird to not really think about your amps for months on end, unless it's "Dayummmm..."I'm between preamps now and have drafted in a 30 year old Forte solid state pre and the amps still sound great. Thinking Brooklyn Dac + direct to amps...
Try the Brooklyn...
200w HDPlex is on the way...
I am also a tube lover and the DAC amps are the only digital amps I've heard that I could live with. They are really great sounding and the best digital amps I've heard.
I've been so enamored with Jeremy's TDA7297 amp that I didn't even make an offer. I've got a pair of EL84 amps that Gary D built for me that I'll keep as log as I can hear, but I'm not in the market to buy. Chip amps are the real deal, and the bang for the buck is unmatchable.
Class D has improved remarkably over the years...
Tubes have their strong points from a sonic perspective as well...
Wind,If you are considering moving to the Triode Masters, I just asked Tommy how the the amps do with a 16 ohm load.
I did consider the Triode Masters, but I chose to put that money (and then some) into cable upgrades. The next step up will be either the X-1, or the X-2, or perhaps even the Lumina. As far as the Maraschinos go, impedance whether it be high or low is a non issue.
