SW-8-16FR Sealed
0 Members and 1 Guest are viewing this topic. Read 467 times.
SW-8-16FR Sealed
« on: 7 Dec 2017, 04:00 am »
Has anyone heard or used them in a sealed enclosure? What would be involved with using them
with the HX-300 amp and can 3 be used with the amp when used in a sealed enclosure. They must
have far more output sealed than they do in OB.
I was thinking about building a Super-V, Super 7 lookalike using the 8's on the bottom and maybe a N series
kit on top for HT. Plus rebuilding my Wedgies with 12's since I know now they are easy to build.
Danny Richie
    • http://www.gr-research.com
Re: SW-8-16FR Sealed
« Reply #1 on: 7 Dec 2017, 03:46 pm »
Sealed air space for that model gets pretty large.
You could drive three of them with the HX300 amp.
And the output level in a sealed box is greater, but not by a lot.
