XLR LFE Input with Active Crossover vs using built in low pass filter
0 Members and 1 Guest are viewing this topic. Read 307 times.
topx
Hello,
I am finding it difficult to sift through the information on the various options for the amp.  Has someone tested using the LFE (which according to one piece I read has a wider ranger?) vs filtering at the sub?
HAL
I do that with my HX800XLR3 servo amps using the XLR inputs and external DSP crossover to my main speakers.  Works great.
topx
thanks for responding!
To clarify you do preamp -> sub -> dsp -> main speakers or
preamp -> dsp -> sub
                         -> main speakers
HAL
Music server -> DSP Crossover -> Subs
Analog Source->                      -> Amps
Mine is a tri-amp setup with all balanced connections.  The DSP crossover takes all inputs and drives all outputs.  I have delay running between the mains and subs for time alignment.
Danny Richie
    • http://www.gr-research.com
Rich's (HAL) setup is fairly unique. It is the only DSP crossover system out there that is truly a high end piece of gear.
Outside of Rich's set up I would try to keep that type of product out of the signal path and just send a full range signal to the servo amp and use the controls there to handle everything.
