X-CS wiring
0 Members and 1 Guest are viewing this topic. Read 323 times.
lacro
X-CS wiring
« on: 23 Nov 2017, 12:53 pm »
What is the correct way to wire the X-CS Encore?  Should each woofer be wired individually in parallel directly to the Crossover PCB, or daisy chained woofer to woofer then to the PCB? Also, The wider terminals on all drivers are + is that correct?
S Clark
  • Measurements don't make your toes tap
Re: X-CS wiring
« Reply #1 on: 23 Nov 2017, 01:33 pm »
Separate wires or daisy chained shouldn't make any difference.  Positive terminal are wide, negative narrow.
mlundy57
Re: X-CS wiring
« Reply #2 on: 23 Nov 2017, 03:33 pm »
Daisy chain uses the least amount of wire and fewest connections
Mike
lacro
Re: X-CS wiring
« Reply #3 on: 23 Nov 2017, 10:42 pm »
Thanks guys for the suggestions. The woofer terminals are pretty flimsy, especially with stiff solid core wire, so I wired both speakers at the Crossover PCB. Worked out well. Currently burning it in with a mono chip amp, before adding it as a center channel in my HT set-up. I will soon post pics in my original X-CS Encore build thread.
