Firefox 57.0 64bit still crashes
0 Members and 1 Guest are viewing this topic. Read 2226 times.
« on: 19 Nov 2017, 07:13 pm »
Firefox 57.0 are still crashes same as earlier versiosn!!
As they are incompetent to solve the problem they have posted a popup warning:
Opening many Tabs may slow Firefox.
This crap hangs just now with only 2 tabs:
Audio Circle and Google Translator.
Seems Firefox 57 64bits and Google Translator and Google Mail are incompatible.
jseymour
Re: Firefox 57 64bit still crashes
« Reply #1 on: 19 Nov 2017, 07:20 pm »
I think something else is going on.  I am using Firefox 57 and Google Translate.  I just translated a Polish website selling tubes with no issues.
Is your Windows up to date?
Re: Firefox 57.0 64bit still crashes
« Reply #2 on: 19 Nov 2017, 07:21 pm »
Yes:
Official Windows 10 Pro 64 Creators
Version   10.0.15063 Build 15063
jseymour
« Reply #3 on: 19 Nov 2017, 07:28 pm »
I have the same OS Build.  You might have a Windows Registry issue.  I run Glary Utilities on a weekly basis.  I use their "1-Click Maintenance" feature that cleans up your PC and fixes the registry.
https://www.glarysoft.com/glary-utilities/
« Reply #4 on: 19 Nov 2017, 07:50 pm »
Thanks I will try it;
« Reply #5 on: 19 Nov 2017, 08:23 pm »
Registry: 198 probs found
Temp Files: 2331 MB files found
What do you rec?
jseymour
« Reply #6 on: 19 Nov 2017, 08:59 pm »
Have it "auto fix" the problems.
audio.bill
« Reply #7 on: 19 Nov 2017, 09:16 pm »
Found this article which provides registration info which you can input for a free upgrade to the PRO edition of Glary Utilities.
https://lifehacker.com/5991897/grab-glary-utilities-pro-for-free-normally-40
« Reply #8 on: 19 Nov 2017, 09:40 pm »
Thanks Seymour I just reboot and PC seems OK :thumb:
jseymour
« Reply #9 on: 19 Nov 2017, 10:47 pm »
Happy that I could help.
« Reply #10 on: 28 Nov 2017, 12:51 am »
Seems the prob was solved w/the registry cleaning, Thanks.
Now doing others items on Glary menu I wonder what exactly do Tracker Eraser?
Removes history, most recent used lists MRU List and other evidence of the Microsoft Windows
What it means? Glary will delete alot of important files from system or no?
Situation is 2090 problems/26.8MB found on database to be removed!
jseymour
« Reply #11 on: 28 Nov 2017, 12:57 am »
Windows keeps track of your browser history.  Glary will delete/clean that if you check Tracks Eraser.  They are not important files.  I do everything except Disk Repair.
« Reply #12 on: 28 Nov 2017, 01:07 am »
Thanks again Seymour for help!!
On disk repair I had 1 prob only showed on the first scan but today it gone :scratch:
So I think I will clean it, Thanks :thumb:
Elizabeth
« Reply #13 on: 28 Nov 2017, 03:28 am »
I have never had FireFox crash or do anything funky.
Years of use.
Microsoft 7 then, now 10.
But I clean my registry every few months..
bacobits1
« Reply #14 on: 28 Nov 2017, 04:35 am »
No problems here ever with FF, now I'm running the Quantum 58.0b7 beta 64 still no problem.
I have used CCleaner over 10 years always the paid version.
Win 7 long time and 10 the last 2 years almost now. Still never a problem.
Anti virus is Win 10 and also run maleware bytes.
« Last Edit: 28 Nov 2017, 06:02 pm by bacobits1 »
« Reply #15 on: 1 Jan 2018, 06:57 pm »
After the registry cleaning that Seymour suggested my FF 57 are running OK.
mav52
« Reply #16 on: 1 Jan 2018, 07:28 pm »
No problem here with FF. I'm on 57.0.3 (64 bit)
jpm
« Reply #17 on: 1 Jan 2018, 10:21 pm »
I ran into some problems with FireFox Quantum (57) and Pocket a while back that were resolved by disabling / removing addons and then re-enabling or reinstalling them. I don't recall more exactly which I disabled / removed, but it was a one time thing and is worth filing away for future reference in case of annoying behavior.
