0 Members and 1 Guest are viewing this topic. Read 18585 times.
...but I like the +6db 60Hz and below bass boost which is an option on the itube2. I'll try your suggestion next week and report back
pstrisikI think you made an excellent purchase with the DAC 3. In Europe it is more complicated to buy Benchmark hard.In EU, a great option, from world pro: RME ADI-2 Pro. But it is not a preamp.https://www.rme-audio.de/en/products/adi_2-pro.php
I heard ALL 14 amps.1º F5 Juma. I love the sound.2º VHex+ . It seems doped. Much bass, some anecoic sound. Maybe is the ideal with orchestral music.3º Quasi. Sweet, warm. It needs more energy and highs. To listen vocal music.I think that F5 Juma has the best of VHex+ and Quasi. Problem, to me, it has very little power to move my KEF Q100 speakers (86dB and 4.7 Ohms minimum). Am I wrong?And yes, your speakers sound very bad with orchestral music.
Capacitor multipliers make low-frequency filter and long-duration timing circuits possible that would be impractical with actual capacitors. Another application is in DC power supplies where very low ripple voltage (under load) is of paramount importance, such as in class-A amplifiers.
The Mac Mini is an excellent audio device, not expensive, never had or needed a fan. But whatever works for you; I'm not one to push my choices on others....
I do not agree: it has a very dirty SMPS!Those old days of the first Mac, MS-DOS, Windows 3.11 and UNIX...************ *********** ************OFF TOPIC againAKSA's Lender Preamp with 40Vpp Ouput GBhttp://www.diyaudio.com/forums/group-buys/315521-aksas-lender-preamp-40vpp-ouput-gb.html
{snip}I am basically flying blind with the volume control on the Benchmark now. You can see where I added some white electrical tape to the volume knob to try to see it better, but still doesn't work well in a very dim room. I might have to get a relatively dim LED to illuminate the knob!{snip}.......Peter
SRB, I had the same thought. I don't think I have a mismatch on impedance (I'll check the numbers and if I recall one wants the receiving gear and the sending gear to have a 10 times difference) , but I like the +6db 60Hz and below bass boost which is an option on the itube2. I'll try your suggestion next week and report back
