0 Members and 1 Guest are viewing this topic. Read 6143 times.
Have you thought about just adding a power amp to the pre outs and using the receiver for a preamp? Look around, you could find some good amps used in your price, perhaps a Parasound A21.
Parasound P5
Remind me what your main speakers are? Also, what type of sound do you like?
I actually think the Rotel RC-1570 might be better? Thats what i'm currently researching, seems like it has a bit warmer/less analytical sound, a bit cheaper used, and also has bluetooth. Lacks the sub controls of the P5 but I already have a miniDSP that can pick up that slack. Thoughts?
Looks like a nice unit, but it doesn't seem to offer home theater bypass. And, unlike the P5, only offers MM phono input.
Rated power (1% THD + N, 1 kHz) [W] 8 Ω, 2x 80 Rated power (1% THD + N, 1 kHz) [W] 4 Ω, 2x 138 Sensitivity (for maximum power) [V] 1x 0.69 Signal-to-noise ratio (A-weighted filter, with respect to 1W) [dB] 89 Dynamics [dB] 108 Attenuation factor (with respect to 4 Ω) 92
75 plus 75 W (at 8 Ω) - as Hegel promises. I managed to get even a bit more, 2 x 80 W at 8 Ω, and each of the terminals independently has a power of 85 W. With a load of 4 Ω it crashes without problems - 149 watts at one driven channel and 2 x 138 watts at two.The sensitivity is not close to the standard (200 mV), it is much less because 0.69 V, the display on the display will oscillate closer to maximum values, which you just have to get used to.Hegel can boast of very low noise level; S / N is 89 dB (this is by far the best result in this group and one of the best among integrated amplifiers in general), thanks to which the dynamics are climbing to 108 dB - which is also the test record.The frequency response (Fig. 1) is exceptionally good with a drop of -0.5 dB at 10 Hz and a good high-tone condition at 100 Hz. The 8 ohms drop is -0.5 dB and for 4 Ω -1 dB. It is also difficult to complain about the spectrum of distortion (Figure 2), none of the harmonics exceeds the safe limit of -90 dB. The strongest is the third at -91 dB, one decibel below the second.The diagram of Fig. 3 is a dot above the "and" of the amplifier's excellent amplitude, over the entire output range (excluding the overdrive area). THD + N remains below 0.1% and plays at least 3W for 8Ω and 6 W for 4 Ω, you can go below 0.01%. Excellently!
HEGEL H80[Polish] https://audio.com.pl/testy/stereo/wzmacniacze-stereo/2446-hegel-h80to English with Google[French] http://blog.son-video.com/2014/03/test-ampli-stereo-dac-hegel-h80/[English] http://blog.son-video.com/en/2014/03/review-hegel-h80-dac-stereo-amplifier/
You mentioned you lean warm, I think the Hegel will make a great music listening amp with the Spacial. Hope you come back and post after some listening time.
