The All New and Different Firefox.
0 Members and 1 Guest are viewing this topic. Read 3802 times.
Speedskater
  • Kevin
Re: The All New and Different Firefox.
« Reply #20 on: 10 Jan 2018, 07:27 pm »
To see the entire add-ons type in the Power Shell as admin:
Get-AppxPackage -AllUsers
They are many, some are need to the W10 proper running.
The deletable are a half dozen.
Power Shell as admin? (Firefox) (or Windows)
How do I get there?
GentleBender
« Reply #21 on: 10 Jan 2018, 07:42 pm »
How do I get there?
PowerShell allows you to use scripts and commands (replaced Command line) and is normally intended for Windows Server and Desktop Admins. Very much like Terminal is for Mac OS it allows you to change, delete items that are not easily accessible otherwise as well as run custom scripts to make short work of many tasks plus so much more. It can be destructive if not used properly. Use with caution!
In Windows 7 it is under Start/All Programs/Accessories/Windows PowerShell
« Reply #22 on: 10 Jan 2018, 07:46 pm »
Right Bender, I see Power Shell as a new evolved DOS.
Or type Power Shell in the Search Window.
« Reply #23 on: 27 Jan 2018, 06:07 pm »
FF updated to 58.0 hmm
« Reply #24 on: 2 May 2018, 02:24 am »
Today Firefox 59.0.3 (Fix for compatibility with Windows 10 April 2018 update, Bug 1452619)
