0 Members and 1 Guest are viewing this topic. Read 3814 times.
Seems the Classic Theme Restorer is avaliable for FF57 w/this app??This is correct?https://github.com/Aris-t2/CustomCSSforFx/issues/2
Mac version runs well, most of my plugins work fine.
So I just updated to 57.0.4 and hate the look. And searching for add-ons is just impossible (it's always been a challenge, but it's now 2018 you would think that they could arrange things in a coherent way.Please tell me, how do I get back to 56 ?
Is there any way to do a real add-ons search?
You cant retro update, maybe full uninstall if you find the 56 on the web, maybe it will self update to 57 too after some time.
Not sure what problem you're experiencing... I just go to the Open Menu and select Add-ons, and then enter my search terms in the search bar at the upper right of the screen. Then ensure that the button corresponding to Available Add-ons (rather than My Add-ons) is selected and at the bottom of the initial results you can select the option to see all results for the search terms entered.
