GR Research Build Threads
0 Members and 1 Guest are viewing this topic. Read 1112 times.
Peter J
  • Hmmmm
« on: 6 Nov 2017, 10:10 pm »
I've been talking to Danny about an index of sorts linking individual build threads for all things GR Research. A sticky master thread kind of thing.  I suspect many would find them helpful in their own builds, but many are buried in the archives. Folks with existing threads are encouraged to LINK them here. It's not intended to be a massive compilation but rather a jumping off spot. I'll start if off with examples done over the years.
Peter J
  • Hmmmm
« Last Edit: 7 Nov 2017, 12:17 am by Peter J »
Re: GR Research Build Threads
« Reply #2 on: 6 Nov 2017, 11:43 pm »
Here's a couple more
OB7 Build
http://www.audiocircle.com/index.php?topic=114219.0
N3 Buiold  (fonrt vented)
http://www.audiocircle.com/index.php?topic=108845.0
Dual 12" OB H-Frames (non  flat ack versions)
http://www.audiocircle.com/index.php?topic=127533.0
Triple 12" OB H-Frame (non flat pack version)
http://www.audiocircle.com/index.php?topic=134523.0
Mini build  X - LS Encores
http://www.audiocircle.com/index.php?topic=144419.msg1543794#msg1543794
Will dig up some more  later
jay
jeffh
ebag4
« Reply #4 on: 7 Nov 2017, 01:16 am »
NX Otica MTM and Dual Servo Subs in H Frame
http://www.audiocircle.com/index.php?topic=146187.0
Multiple Wedgie Builds (linked to the first page with a build starting)
http://www.audiocircle.com/index.php?topic=126112.380
hesster
« Reply #6 on: 8 Nov 2017, 12:44 pm »
My LS-9's which have held up well over the years, a killer Line Array, but no easy build task.  Too bad they are discontinued!  I power them with Emotiva gear - XMC-1 Processor and (2) XPR-1 amps.
http://www.audiocircle.com/index.php?topic=80580.msg771669#msg771669
BK_856er
« Reply #7 on: 12 Nov 2017, 08:02 pm »
Voncarlos
  • OB5s in Stripes
« Reply #8 on: 14 Nov 2017, 03:22 pm »
And a link to my OB-5 build. My avatar is the finished speaker.
http://www.audiocircle.com/index.php?topic=59326.0
Thanks Peter
