Sub questions
0 Members and 1 Guest are viewing this topic. Read 394 times.
studley
Sub questions
« on: 6 Nov 2017, 10:51 am »
I have a couple of questions:
1. When using the 12-04 driver in a sealed box, what is the usable frequency range?   In particular what is the highest frequency you would not want to go beyond?
2. The plans suggest using 3/4 inch MDF.  Could I use 1 inch, or would that make the baffle too thick for properly seating the driver?
Danny Richie
    • http://www.gr-research.com
Re: Sub questions
« Reply #1 on: 6 Nov 2017, 03:21 pm »
Range is about 16Hz to 125Hz.
Thicker is good. We even have a version of the box called the sand box that is rock solid. The more solid it is the better it will sound.
