0 Members and 1 Guest are viewing this topic. Read 21436 times.
The human stomach is contains hydrochloric acid, which along with native bacteria, digest the food we eat. If you were to put a drop of saliva on a strip of PH paper, it would show even that is slightly acidic. No "alkaline diet for" me, because I believe you are wrong.
Nope. Prove it to me by citing a specific reference, or prove it to yourself by putting a drop of saliva on a piece of litmus or pH paper.
pH of saliva easily checked by googling, so no further comment on that one but the pH of the stomach can be 3.5 or lower, so it's quite acid.There's a heap of work being done currently on gut biota with some strong links showing up between the state of your gut and your mental health. If you can watch this program:http://iview.abc.net.au/programs/catalyst/SC1502H024S00 and its follow up I think you'll be impressed.I'm somewhat skeptical of the alkaline diet. I quite understand why bicarbonate is used where excessive acid in the gut is a problem. [bicarb. isn't strictly speaking alkaline. There's a reaction between sodium bicarbonate and any acid eg hydrochloric acid to produce CO2 gas and a salt, in the case of HCl the salt would be sodium chloride, ie common salt]. Taking sodium as an example of a useful alkaline mineral is not a great idea! If you were to swallow sodium, the metal, you'd have a massive and dramatic reaction in your throat and gut producing huge amounts of heat and even flames, large amounts of hydrogen gas and death. There are sodium compounds that are alkaline, notably sodium hydroxide but it's also known as caustic soda which could also cause ... death. Of course common salt is sodium chloride which is neutral and relatively harmless if not overdone and there are many other compounds containing sodium.Swallowing Potassium could also cause death but my point really is, that the pH given for these elements probably relates to compounds like hyroxides and while Magnesium and Calcium hyroxide are relatively innocuous, the rest aren't.I notice that quite a few acid substances are listed as being alkalinizing and I'd suggest that to get the pH of blood and other parts of the body away from the digestive tract, to the desirable slightly alkaline level of 7.4 [which is only slightly above the neutral value 7.00] the best approach will be to feed your gut biota a range of foods that keep a balance between the many, many different bacteria with different roles to play in your health. So, if you can, please take a look at the Catalyst program mentioned above and its follow up. [that's if they're viewable outside Australia??]
These last two replies [above] sound reasonable, and I will look into them for my own information. The only point I would like to add is that I worked in an analytical chemistry laboratory for many years, and value "finding out for myself" when it comes to the determination of pH. This is easy to do with litmus paper or pH paper.
