0 Members and 1 Guest are viewing this topic. Read 9564 times.
The second is the power light is WAY too bright, so will have to mod it with some tape and a hole punch.
Wanted to update my thoughts about using one of these as a loudness control, I feel it works great in my system for such. I have the two right hand controls set at around 10 o'clock, and the two left hand controls set at 2 o'clock. Nothing measured, just adjusted by ear. At a low 50-60 db sound level, the music is more balanced and mellow, then with the Loki switched into bypass. Neat little addition that will come in handy often.
BTW, Very cool audio rack too!
Hi, Do you noted the soundstage had increased size?
After seeing the eq curves at 4:40 its clear that this unit is a heavy hand paramentric eq, studio engineers and musicians would like it, its so inexpensive.
