0 Members and 1 Guest are viewing this topic. Read 9507 times.
I would be interested in it if it were balanced.
Yes, the LIGHTDIMS work great!
I've had one for a few weeks. Totally transparent. Love it.
Transparent when used w/HPs or speakers?
Did you order it with the expert installation for an extra $123? Seriously though, seems like a really good idea for a product.
Forgive my ignorance, but how can tone controls be transparent? The device is designed to color the sound. Maybe I'm not understanding the unspoken but often used audiophile dictionary.
I've had one for a few weeks. I mostly use a small cut on the 20 hz dial. This cleans up the bass in my room nicely. Makes the lower mids much more clear. Some vocals are the best I have heard in my system. On lp's that tend to the bright side a small cut on the 20k band and maybe on the 2k makes it much easier on my ringing old ears. For now it is a keeper.
Do you can hear 20Khz? Per chance your name is Bruce Wayne?
Can't even hear 14k. Also had a brain fart and meant to type 8k not 20k.
https://www.youtube.com/watch?v=i6oyxHGJbsM According to the video posted above, the 20 Hz knob has a wide Q. It affects 50 Hz and 100 Hz almost as much as it affects 20 Hz. At about 4:40 in the video you can see what the EQ curves look like for each of the knobs. no Bruce Wayne needed.
