0 Members and 1 Guest are viewing this topic. Read 3854 times.
Joe G, I've had both a VPI Classic original with JMW arm and an Avid Diva II w/ Origin Live Silver II arm. I used a Shelter 501 MkII cartridge. I liked both of them. The VPI had a more incisive crisp sound--call it more lively. The Diva II was slightly airier and more pleasant to listen to with less than excellent recordings. Price of either with arm was similar--about $2100. I bought the Classic new on sale at about $1800 and the Diva with OL arm was bought used for the $2100. I liked the OL arm better as it doesn't wobble around due to its inherent design. I got one of the Pete Riggle VTA bases to use with the OL arm. It improved the sound slightly and made it real easy to remove the arm from the TT if needed.I used these with VMPS RM40 which are very resolving and dynamic speakers. The system is very resolving but with a tube preamp that softens the mids a little.
If you are keeping the Concept MC and it really has a compliance of 9/9 µ/mN, you would need a heavy arm. If you go with VPI prime that has a 3D arm, you would need to use heavy screws like the ones Soundsmith offers. If you do some reading and connect with local guys who would help, you don't need to deal with a dealer. That will open up a used market where you can really get good stuff for 3 to 4 K, e.g. https://www.audiogon.com/listings/turntables-turntable-w-sme-5-arm-2017-10-12-analog But then, you would need to upgrade the cart and phono stage to do justice to the table/arm. In this hobby, you are only going to hear the best your worst equipment in the chain will allow. So you have to kind of move in lockstep or you won't hear an upgrade. I don't know enough about your system to know if you are going to hear any upgrade from the Concept system.
VPI Prime owner and don't think you could go wrong with a Prime but for some reason I'm infatuated with the Gem Dandy Super12 Polytable. FYI, there is a fully loaded 9" Polytable on Agon and SoundStageDirect has a CPO Performance DC with the Clarify arm in you price range.
I'm gonna add the Kuzma stabi s to the list. Any thoughts?
Where are you, just put my Prime up for sale here and US Audimart
