0 Members and 1 Guest are viewing this topic. Read 2608 times.
I like to use shellac for that.
WTF? Sure you are in a hurry but since you don't know what the top coat is you may be applying an incompatible primer/sealer. The primer has to be compatible with the top coat.
I would be afraid to sit on MDF platform held by legs... I would have laminated some maple for that.
Are there no easy water based recommendations?
Amazing work, WGH!
