0 Members and 1 Guest are viewing this topic. Read 8722 times.
Even if a $1500 high quality CDP or transport can beat computer based player, if you use it a lot the transport will crap out in a couple of years and you are left with an unrepairable $1500 door stop.I would never buy a used transport...
There's no question a server is more convenient. There is potential for a server to perform better than a cd player, but it's not a given and system specific. It can be a lot of work, and frustrating as well if you're not comfortable with computers. Some of the network players will allow you to stream Tidal if you wish (Sonore Rendu, SOTM network players) as well as playing your files.
I think WIN Creator 10 is probably a game changer for a Windows based system, as this is the first time Windows has ever supported 24/192 playback with a OS level driver. This allows you to bypass factory ASIO drivers for all playback applications 24/192 and lower. I have also been able playback DSD 128 and DSD 256 DSD-DSF files with jRiver 22 using 24 bit integer setting. At the end of the day, when all is said and done, you are listening to software when you listen to music using a PC as a source. The better the software is, the the better the music sounds. It appears that a factory supplied ASIO driver may not be the best possible alternative to an OS level driver doing the same job. Does the factory ASIO driver sound better than the OS level driver. In every instance this is a comparison that needs to be made and a question that needs to be answered. The player software chosen also has an audible impact on the music and is avenue to potential future improvements in sound quality. Without spending a lot of money.Scotty
I really appreciate the great responses, guys. Yeah, I'd definitely be more interested in a plug & play option. Also, the majority of the music I listen to isn't available in a hi-rez digital format, so I'd be copying CDs. May not be worth the trouble. I dunno. The technical stuff that Scotty is talking about may be simple for some people, but I just want to hear music, not fiddle around with software and settings and such.
Personally, I think using Roon with Tidal is pretty much end game for me right now. I take USB out of my PC, into a Mutec, and out to my DAC. Sounds good, is easy to use, and I can control it headless from my phone. I too got tired of ripping my CDS, so I just stopped. Tidal is good enough for now.
