0 Members and 1 Guest are viewing this topic. Read 6872 times.
Unrelated: Which Salks do you have and are you using the Ascends as surrounds?
Unfortunately velour pads atract dust, needing cleaning.
Two people here mentioned the AKG K7xx and Shure SRH-840, both good headphones and both fairly close to the classic 'neutral' signature. But the HP-50 as far as I know has the "relaxed" treble that's sometimes known as the "room feel" sound. Just so the OP knows that headphones with a relaxed treble (AQ NightHawk, Sennheiser Momentum, Focal Elear, Sonus Faber Pryma, others....) are very popular now, but are a different kind of signature from the classic neutral types.
i started my headphone journey with the Sennheiser HD 555 maybe 6 years ago. I use this can every week on my portable devices. If I were to upgrade from those it would be the HD 598 (open back). They add a touch more refinement and air than the 555's to my ears. I've heard Senn's lower, middle and upper class models... never disliked the sound, build quality and presentation. So the HD 598 is my recommendation.
