V25 Preamp Controller - External Control Via UART Commands
0 Members and 1 Guest are viewing this topic. Read 1346 times.
tortugaranger
    • Tortuga Audio
Hi All,
The V25 preamp controller can now be controlled by any external control device via simple 2-wire UART serial communications using a set of fairly simple commands. Such external devices might include an Arduino type microcontroller, a PC, a MAC or any other device with programmable UART communications.
This External Control feature is documented in our online Product Documentation which can be found via this link: https://www.tortugaaudio.com/support/product-documentation
Click on "V25 Preamp Controller" to show the menu and then select the submenu item "V25 UART Command Codes".
I've created this as a separate sticky topic since user Q&A on this will likely be fairly technical and relevant only to DIY'ers.
Enjoy!    :thumb:
Morten
Re: V25 Preamp Controller - External Control Via UART Commands
« Reply #1 on: 4 Sep 2017, 09:53 pm »
Cool. Now I just need my V25 board. :)
I'm sure I will have a few questions as I dig into it.
