0 Members and 1 Guest are viewing this topic. Read 5281 times.
I own Super V's and Rocket's comments are right on. They need way more power than the 97db "at least that's what I think they are rated" would suggest. I have tried several flee watt amps including tubed, SS and class D and have never been able to really get the P Audio drivers moving without at least 50 wpc. The crossovers being the cause makes a lot of sense and is what I also have suspected all along. Yes, you have to adjust the subs volume control way down to get a flee watt amp to be an even output and vise versa with a large amp. About two weeks ago a friend brought over a tube amp with 8wpc. I had to almost turn off the subs volume to get them to match up in output. And Dieterle, yes you are a Tool. Greg
In defense of the Micro ZOTL, I have two of ey sound spectacular as a one watt integrated amp. I have used them to power my Tekton Double Impacts and also my Decware ERRx radial speakers and at 93 db they did a respectable job with decent volume.The real magic of this little amp is when it is used as a preamp. This is where it really shines. It is the best preamp I've ever owned, probably ever heard. I really suggest trying its preamp capabilities. You will be stunned. I'm using some primo NOS tubes and it really is a tube rollers dream.
It is quite likely that you guys have an extreme balance issue
