High(er) quality Power Supply for Mini ITX cpu?
0 Members and 1 Guest are viewing this topic. Read 769 times.
kenreau
« on: 30 Aug 2017, 10:42 pm »
Looking for recommendations for a higher quality power supply to a Mini ITX pfSense Firewall / Router with Inel Atom processor I have.  All my network access flows through it and I would like to find a good, solid quality, quiet power supply.  I imagine that would be a linear power supply, but open to suggestions.  The stock ps it came with looks like a typical generic commodity laptop brick switching supply, it puts out 12VDC at 6.6Amps.
I'm no longer in the computer audiophile realm and my notion is I don't need an uber audiophile power supply like Uptone, Paul Pang or Paul Hynes supply.  Possibly could go for a Teradak or Teddy Pardo level if no solid quiet switching supplies are available.  I have a couple of the iFi power supplies and really like them, but they don't offer anything about about 2amps.
Kenreau
lowtech
Re: High(er) quality Power Supply for Mini ITX cpu?
« Reply #1 on: 31 Aug 2017, 03:54 am »
With very little effort you can use an X-Box power supply, which is capable of delivering 12.1A @12v.  Been using one to power my Mini-ITX Core i7 workstation for many years.  You can find used working ones for cheap.
If you want additional uptime/failover functionality you can plug your appliance into one of these, which will power cycle the device if it cannot ping a specified IP address.
kenreau
« Reply #2 on: 31 Aug 2017, 03:35 pm »
Is there something special about the xbox power supplies?  I assumed they were a basic, noisey switching power supply.
Kenreau
lowtech
« Reply #3 on: 31 Aug 2017, 05:11 pm »
Which leads to the question:  Is there something wrong with your existing power supply or are you just being OCD?
JRace
  • Greetings one and Everyone!
« Reply #4 on: 4 Sep 2017, 04:57 pm »
Then why are you looking for anything new?
There is zero effect on your audio components, so other than uptime there would be no change.
