Cherry Amp Reference Info
0 Members and 1 Guest are viewing this topic. Read 744 times.
AmpDesigner333
« on: 30 Aug 2017, 12:19 pm »
Putting up some some packing lists and other information to assist ordering....
AmpDesigner333
Packing Lists for Desktop Maraschinos and Customization Options
« Reply #1 on: 30 Aug 2017, 12:27 pm »
What's in the box (new 36V Desktop Maraschino):
    (2) 36V Universal AC Power Supply
    (2) Maraschino Desktop Amplifier with Dayton Posts, Granite or Marble Base
    (2) RCA-to-XLR Adapter
    (2) AC Line Cord
    (1) Instruction Sheet
What's in the box (new 48V Desktop Maraschino):
    (2) 48V Medical Grade Universal AC Power Supply
    (2) AC Line Cord
What's in the box (new 60V Desktop Maraschino):
    (2) 60V 1kW Power Supply, 120VAC or 240VAC
    (2) Standard DC Cable
    (2) AC Line Cord
What's in the box (new KING Desktop Maraschino):
    (2) Maraschino Desktop Amplifier with Gold WBT Posts, Aluminum Base
    (2) 3-foot DC_SNAKE Low Impedance Braided Cable
    (2) AC Line Cord
What's in the box (new Golden Cherry Desktop Maraschino):
    (2) Maraschino Desktop Amplifier with Gold WBT Posts, Aluminum Base, Gold Enclosure, Triple Capacitance, Tweaked Modulator, Sleep Mode Disabled
    (2) 6-inch DC_SNAKE Low Impedance Braided Cable
    (2) AC Line Cord
What can be customized for Desktop Maraschino Monoblocks:
    A) LED color ---- Red (standard), Blue
    B) Base type ---- Granite or Marble (standard), Solid Aluminum
    C) DC Cable (for 60V 1kW Power Supply) ---- DC_Cable (standard), 3-foot DC_SNAKE, 6-inch DC_SNAKE
    D) Enclosure color ---- Black (standard), Red, Silver, Bare Metal, Gold (only for Golden Cherry version)
    E) Sleep Mode Disable ---- Prevents the amp from entering sleep mode
    F) Double Cap Mod ---- Double bulk capacitance (can also be done for In-Line Maraschinos)
    G) Triple Cap Mod ---- Triple bulk capacitance (standard in Golden Cherry)
    H) 36V Power Supply ---- For high efficiency speakers
AmpDesigner333
Desktop and In-Line Maraschino Power Output
« Reply #2 on: 30 Aug 2017, 12:28 pm »
36V Output Power (Maraschino Monoblock):
    70Wpc into 8Ω
    145Wpc into 4Ω
    145Wpc into 2Ω
48V Output Power (Maraschino Monoblock):
    140Wpc into 8Ω
    250Wpc into 4Ω
    250Wpc into 2Ω
60V Output Power (Maraschino Monoblock):
    200Wpc into 8Ω
    400Wpc into 4Ω
    800Wpc into 2Ω
AmpDesigner333
Stereo Maraschino Switch Positions and Power Modes
« Reply #3 on: 6 Sep 2017, 01:57 am »
Initial turn-on:
    - Make sure the volume is all the way down.
    - Make sure the left switch is set to MUTE.
    - Make sure the right switch is set to OFF.
Left switch positions (Input Select):
    - UP = Front (1/8” jack, Single Ended)
    - MIDDLE = MUTE
    - DOWN = Rear (XLR, True Balanced)
Right switch positions (Power Mode):
    - UP = ON
    - MIDDLE = AUTO (amp will sleep after 8 minutes of no audio)
    - DOWN = OFF
Power LED:
    - RED = Standby
    - GREEN = Running
    - ORANGE = Running at high voltage (60V)
AmpDesigner333
AmpDesigner333
Cherry Amplifier (R) Comparison Chart
« Reply #5 on: 29 Sep 2017, 10:33 pm »
                                                          Minimum  Channels     Wpc        Wpc       USD List
Model                        Type            Bandwidth     Load     per amp   into 4Ω    into 8Ω    Price (new)
Classic Cherry Stereo        Stereo Amp      1Hz - 60kHz    4Ω         2       600        360         $2,100
Classic Cherry MONO          Mono Amp        1Hz - 60kHz    4Ω         1       650        390         $3,000/pr
Classic Cherry ULTRA Stereo  Stereo Amp      1Hz - 60kHz    4Ω         2       675        400         $3,900
Classic Cherry ULTRA MONO    Mono Amp        1Hz - 60kHz    4Ω         1       770        420         $7,000/pr
Desktop Maraschino           Mono Amp        0 - 100kHz     2Ω         1       145 (36V)  70  (36V)   $2,500/pr
        250 (48V)  125 (48V)   $2,500/pr
        400 (60V)  200 (60V)   $3,500/pr
KING 60V Desktop Maraschino  Mono Amp        0 - 100kHz     2Ω         1       400        200         $4,000/pr
Golden Cherry                Mono Amp        0 - 100kHz     2Ω         1       400        200         $6,900/pr
In-Line Maraschino           Mono Amp        0 - 100kHz     2Ω         1       145 (36V)  70  (36V)   $1,900/pr
        250 (48V)  125 (48V)   $1,900/pr
KING In-Line Maraschino      Mono Amp        0 - 100kHz     2Ω         1       400        200         $3,100/pr
Stereo Maraschino            Stereo Int Amp  0 - 100kHz     2Ω         2       70  (36V)  70  (36V)   $1,200
        125 (48V)  125 (48V)   $1,200
KING 60V Stereo Maraschino   Stereo Int Amp  0 - 100kHz     2Ω         2       400        200         $1,700
« Last Edit: 1 Nov 2017, 01:01 pm by AmpDesigner333 »
Wind Chaser
Re: Cherry Amp Reference Info
« Reply #6 on: 29 Sep 2017, 10:39 pm »
I'm looking at this chart wondering where my amps fit in.  :scratch:
Tommy, I just sent you an email titled IMPORTANT. I hope you get it before you ship.
John
AmpDesigner333
« Reply #7 on: 29 Sep 2017, 11:05 pm »
John
John,
I sent a reply.  Your amps are KING Desktop Maraschinos, but with 48V power supplies.  This is essentially the same as upgraded (WBT Gold posts) 48V Desktop Maraschinos, so they would have a $2900 list price due to the upgrade, which is $200/amp.  Thanks.
-Tommy O
Wind Chaser
« Reply #8 on: 30 Sep 2017, 02:13 am »
That's cool; I'm really looking forward to having these amps in my system. :green:
AmpDesigner333
Stereo Maraschino Power Output
« Reply #9 on: 6 Nov 2017, 05:28 pm »
36V Output Power (STM):
    70Wpc into 8Ω
    70Wpc into 4Ω
    70Wpc into 2Ω
48V Output Power (STM):
    125Wpc into 8Ω
    125Wpc into 4Ω
    125Wpc into 2Ω
60V Output Power (STM):
    200Wpc into 8Ω
    400Wpc into 4Ω
    500Wpc into 2Ω
