nOrh 6.9 incoming
0 Members and 1 Guest are viewing this topic. Read 3460 times.
SteveSatch
nOrh 6.9 incoming
« on: 26 Aug 2017, 08:39 am »
If you saw them on ebay recently I bought them.  Will post more when they arrive.
jqp
Re: nOrh 6.9 incoming
« Reply #1 on: 27 Aug 2017, 03:15 pm »
looking forward to it
SteveSatch
« Reply #2 on: 2 Sep 2017, 08:59 pm »
fredgarvin
« Reply #3 on: 3 Sep 2017, 06:19 pm »
I remember all about those from the days before we became Audiocircle and still known as Harmonic Discord. I really wanted to get the marble 4., I think they were, for my HT. I still have my IRD Purist from those days.
SteveSatch
« Reply #4 on: 3 Sep 2017, 06:56 pm »
I've had ceramic 4.0 since 2001.  I finally got some marble 4.0 about 18 months ago.  I love the 4.0 for home theater.
Early B.
« Reply #5 on: 3 Sep 2017, 08:49 pm »
Consider upgrading the crossover parts to achieve a better sound. I did so in my 6.5's and it made a big difference.
SteveSatch
« Reply #6 on: 4 Sep 2017, 04:37 pm »
Upgrading crossovers is beyond my abilities
« Reply #7 on: 4 Sep 2017, 04:42 pm »
Still have my 6.9's.  What were they listed under?
Early B.
« Reply #8 on: 4 Sep 2017, 05:48 pm »
It's super easy. All you need is a screwdriver and basic soldering skills. Here's how:
1. In Norh speakers, the crossover isn't soldered to the speakers, it is screwed into the bottom with only one screw, so you can easily remove it. To get to the crossover, remove the woofer, then take out the crossover. Make sure you take note of which wires are connected to the woofer and tweeter, but it's very intuitive.
2. Once the crossover is removed, take pics and post it here. We can tell you which parts to order and where to order them from. You might spend a total of $100 or so.
3. Once the parts arrive, find a friend who can solder if you can't do it yourself. It might take 10 minutes per speaker to complete.
Here is a pic of the stock crossover in my Norhs. Yours will look similar:
SteveSatch
« Reply #9 on: 6 Sep 2017, 02:54 am »
I'd gladly take them to someone in my area (So Cal) who could do it for me and teach me, but I fear I'd mess things up if I tried it myself.
