CDP-8/9
0 Members and 1 Guest are viewing this topic. Read 4862 times.
VintageFlanker
Re: CDP-8/9
« Reply #60 on: 10 Dec 2017, 03:06 am »
VintageFlanker
Re: CDP-8/9
« Reply #61 on: 14 Dec 2017, 02:13 pm »
Also, a first review, which seems to conclude that way:
Upgrade the CDP-9 would be necessary for getting the full performance...
http://review.u-audio.com.tw/reviewdetail.asp?reviewid=1408
From Google Translate :
"Power upgrade, not an option, is required
NuPrime CDP-9 there is a place to upgrade, after trying, I almost think it is necessary to upgrade. That is the power. The CDP-9 is so small that it has CDs, a variety of wires, and no room for power at all. Therefore, the CDP-9 is the only one in the 9 Series that uses an external power supply. The original is attached to the ordinary exchange of power supply, although in line with industry standards, but also the Ming Wei such manufacturers products, but the output is still limited, 15V, 1.2A maximum output. I put KECES P8 linear power supply, this unit is dual-output version of this hand, one cut to 15V, the current output is 4A. The KECES P8 uses toroidal transformers, each with its own output ground and low noise levels. The chassis is made of 4mm thick aluminum alloy and isolates EMI / RFI electromagnetic waves. Put on, the sound of the entire triple jump, not only sound density is more solid, more full thickness, the ups and downs of music and contrast more intense, music dynamic more prominent, and the background is more quiet. Orchestration of large orchestration, whether it is subtle lines in the show, or a large dynamic when the energy sense, are more prominent; and large volume, the dynamic section is more calm and organized. Listen to the difference between the drums even bigger, it seems that the original weight of 200 pounds, plus P8, at least 300 pounds or more, and retractable faster and more neat. Just listen to Dali CD 4 again this album will understand, if you do not understand, put a Michael Jackson, Bao Zhisisha to. In fact, the original design of the CDP-9 should have a separate power supply, NuPrime do not understand the power design, but this way, the price is not so cheap. If you are hesitant to consider audiobooks, please inform the store in advance, prepare a power supply for you, I am afraid you listen to CDP-9 also No commitment to pay, after listening to the power of the sound after the upgrade, it was frozen. "
kaka89
Re: CDP-8/9
« Reply #62 on: 14 Dec 2017, 04:05 pm »
In fact, the original design of the CDP-9 should have a separate power supply, **NuPrime do not understand the power design**, but this way, the price is not so cheap. If you are hesitant to consider audiobooks, please inform the store in advance, prepare a power supply for you, I am afraid you listen to CDP-9 also No commitment to pay, after listening to the power of the sound after the upgrade, it was frozen. "
The correct translation for the second sentence is: "It isn't that NuPrime does not know how to do power design, but the price won't be so cheap if it is included."
The article did strongly suggest upgrade the power supply, I wonder why.
VintageFlanker
Re: CDP-8/9
« Reply #63 on: 14 Dec 2017, 04:34 pm »
Reminds me the case of Chord 2Qute. The designer himself (Rob Watts) strongly claims that a power supply will NOT improve his DAC in any way... but no, many HeadFi membres continue to claim the opposite. I chose to believe Rob Watts in this case.
Any thoughts, Jason?
JackD
Re: CDP-8/9
« Reply #64 on: 15 Dec 2017, 03:07 am »
Not so sure what's so puzzling about the recommendation to upgrade from a supplied wall wart to an outboard linear power supply.  Pretty common place in today's audio marketplace.  Many manufacturers who sell the products with wall warts also sell upgraded power supplies for their own units.  Pretty sure you can find one for a reasonable price from direct sellers like Swagman, HD Plex and TeraDak for a reasonable price.
As an example here is one for the NuForce Icon which used a similar power supply from the factory.
https://www.ebay.com/itm/Teradak-DC-30W-15V-1-6A-NuForce-Icon-HDP-linear-power-supply/222532768560?hash=item33cffc9330:g:twMAAOSwCU1Y0rp1
pawsman
Re: CDP-8/9
« Reply #65 on: 15 Dec 2017, 12:18 pm »
Jason,
If I wanted to upgrade the power supply for my CDP-9, which one would Nuprime recommend?
BTW, I'm enjoying my CDP-9 greatly; I've found that upsampling everything to 768k PCM yields a very
natural, organic sound with Classical orchestral music (my main listening genre)-
pawsman
rustydoglim
Re: CDP-8/9
« Reply #66 on: 21 Dec 2017, 07:42 pm »
People always want to push the limit and squeeze out every ounce of improvement. Any linear power supply that matches the voltage will be ok.
We can't recommend anything else because we don't keep track of what's out there.
yarrob
Re: CDP-8/9
« Reply #67 on: 11 Jan 2018, 12:27 am »
I've had my CDP-9 for two weeks now and listened to CDs only.
Room:
  apartment bedroom/study
System:
  CDP-9 --> AVI DM5 active bookshelf speakers
Primary music:
  Weather Report - Columbia Studio & Live box set
  Naxos 30th Anniversary box set, John Williams - The Guitarist box set
  Motown - Hitsville box set,  80s Miles - Decoy & Star People
Impressions:
  I primarily listen to classical, jazz, R&B and rock.  My previous CDPs have included Linn, Sony ES, and ADCOM.  I would say that while the sound does not hug you, its accuracy and detail can be uncanny.  Similar to other listeners, I found the soundstage to be narrower than expected - especially for the DM5s.  Perhaps this will expand over time, or maybe if used with a different pre/amp.  Regardless, voice, strings, percussion, piano, guitar, etc. are all rendered naturally with accurate timbre, and the separation is excellent.  Live recordings are more nuanced w/ CDP-9 versus my older gear.  Again, like another listener, I enjoy the PCM 768 SRC setting.
  I intend to try some different cables and possibly another PS, but I do think it is very good CDP.  I do not think it is great or a real giant killer given the stage width and a lack of the 'you are there' experience from the best, but it has a very clean and analytical (not distorted) sound. It works for me in my room with AVIs and the music I enjoy.
- yarrob
PS IMO Jazz and CD box sets seem to be a great buy these days.  Incredible, historical music with artwork and notes to boot.
