DA HP cords for DAC Preamp
0 Members and 1 Guest are viewing this topic. Read 306 times.
« on: 8 Aug 2017, 06:27 pm »
I bought 2 HP DA power cords from Pete to use for amps. My system has changed and now only use 1 HP on my stereo amp. Is the HP version the best to use for a DAC or is standard DA recommended?
Triode Pete
Re: DA HP cords for DAC Preamp
« Reply #1 on: 8 Aug 2017, 07:17 pm »
Hi Bob,
The HP version will work wonderfully on your DAC. It may be considered slightly "overkill" for your DAC by some, but I do not believe so...
