Bryston WiFi Dongle Accessory Kit
0 Members and 1 Guest are viewing this topic. Read 1713 times.
unincognito
    • bryston.com
« on: 31 Jul 2017, 04:16 pm »
The Bryston WiFi Dongle Accessory Kit is a product that can be purchased by itself or with the purchase of a Bryston Digital Player.  At the cost of a single USB on the BDP it will gain WiFi capability no longer requiring the user/installer to run a network cable, setting up a WiFi bridge or Powerline AV kit. We are simply offering this WiFi kit for convenience and to remove any guess work from choosing a correct module.  The WiFi Dongle Accessory Kit will be available by September and will correspond with the release of our S2.36 firmware release, which among other things will include comprehensive support for the accessory kit as described in the manual (a preliminary copy is linked below).  The BDP firmware has contained WiFi support since S2.18, however the S2.36 update or newer is highly recommended for this accessory.  The WiFi dongle included in this kit is capable of upto 300Mbps 802.11n and will work with 802.11a/b/g/n wireless capable networks.  Most if not all 802.11ac networks should be backwards compatible with one if not all of these versions.  An 802.11ac dongle wasn’t chosen for a variety of reasons, the primary of which was the limitation USB 2 interface.  The kit will include:
  • WiFi Dongle
  • 3’ USB extension cable (to avoid blocking neighbouring USB Ports and positioning the dongle away from gear if needed)
  • Instructions
http://support.bryston.com/downloads/BDP/WiFi/Manual%20Preliminary2.pdf
Price: TBA
« Last Edit: 31 Jul 2017, 08:53 pm by unincognito »
CanadianMaestro
  • Skepticism is the engine of true progress
Re: Bryston WiFi Dongle Accessory Kit
« Reply #1 on: 31 Jul 2017, 07:40 pm »
Hi Chris,
The dongle is a good idea. Plug and play?
Please put this on the Bryston website eventually.
Pete
unincognito
    • bryston.com
« Reply #2 on: 31 Jul 2017, 08:35 pm »
mostly, theirs an early manual linked in the original post, it should give you an idea of the complexity
Xinon
« Reply #3 on: 31 Jul 2017, 08:38 pm »
Cool.
Can we order it directly from you, or need to order through importer?
unincognito
    • bryston.com
« Reply #4 on: 31 Jul 2017, 08:40 pm »
Just contact your local Bryston dealer, should be available in September when we launch S2.36
Xinon
« Reply #5 on: 31 Jul 2017, 08:58 pm »
Thanks, will do that.
R. Daneel
« Reply #6 on: 6 Aug 2017, 02:57 pm »
Hi Chris!
Can BDP access a WIFI hot-spot created by a mobile phone or tablet using this dongle
Cheers!
Antun
zoom25
« Reply #7 on: 2 Sep 2017, 06:23 pm »
Any update on pricing or availability?
doveman
« Reply #8 on: 10 Sep 2017, 02:50 am »
It doesn't seem to be mentioned anywhere in the manual, but does the BDP-1 support this kit?
CanadianMaestro
« Reply #9 on: 10 Sep 2017, 12:44 pm »
Yes it does. But use the bottom rear jack. Not the front panel jacks.
Hoiman
« Reply #10 on: 12 Sep 2017, 07:17 am »
I also like to know, because I can really use this.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #11 on: 12 Sep 2017, 11:07 am »
Hi
I think its around $80.00 but email me at jamestanner@bryston.com and I will check and get back to you.
james
Hoiman
« Reply #12 on: 12 Sep 2017, 03:35 pm »
I just send a e-mail ;-)
zoom25
« Reply #13 on: 6 Nov 2017, 03:48 am »
Hi James,
Is this being sold anywhere or only directly by Bryston? Is the price finalized?
BigGeek
« Reply #14 on: 26 Nov 2017, 04:21 pm »
Hi James,
I asked my local dealer and he told me this is still "forthcoming". Also I called Audio Advisor and the guy had no idea what I was talking about. What gives?
zoom25
« Reply #15 on: 26 Nov 2017, 04:29 pm »
No idea. Hope someone from Bryston chimes in.
« Reply #16 on: 26 Nov 2017, 05:08 pm »
Hi Folks,
Chris can answer in more detail but basically the DONGLE is a USB Thumbdrive that plugs into the rear of the BDP which allows it to be wireless and attach to your network. Helpful if you can not run an Ethernet cable to your setup.
We are still looking into it but have sent a few out as a beta and so far seems to be working OK.  I think the price will be around $80.00.
We also are working on an internal wireless system for the BDP - which is almost complete. - looking for a name for this option - BONGLE ???
We are also going to be offering SS or Rotary drives as a factory option going forward.
james
unincognito
    • bryston.com
« Reply #17 on: 26 Nov 2017, 07:57 pm »
currently i believe only the wifi usb dongle has made it onto the price list and i believe James is correct, it is $80.  The internal version for the BDP-3 should be available shortly, parts list has been finalized and stock should arrive sometime in December.  Im not sure why the internal storage options arn't listed yet, as far as I am aware we have a small stock of each storage option and is likely just making its way through the paper work.
Chris
zoom25
« Reply #18 on: 26 Nov 2017, 08:42 pm »
I hereby name it...Bryston DONG-1.  :lol:
Second option is: BNA-1 (Bryston Network Adapter)
It's consistent with your naming. You're welcome.
zoom25
« Reply #19 on: 26 Nov 2017, 08:46 pm »
So these are working fine, but are still not being sold officially? Any comments on sound you guys want to make?
I would have loved to try one out and compare MPD (NAS) and Roon via ethernet vs. adapter, as well as against local attached storage.
