Sonore ultraRendu - Ethernet to USB source
0 Members and 1 Guest are viewing this topic. Read 588 times.
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
« on: 23 Jul 2017, 08:46 pm »
DESCRIPTION
The Sonore ultraRendu project is an extension of the microRendu project that we launched over one year ago. The design is inspired by audiophile gear and meant to bring grace and simplicity to a micro computer. The original microRendu was very small and intended to be hidden out of site behind your other gear. The ultraRendu is in a larger case and perfectly matches the Uptone Audio UltraCap LPS-1 power supply. However, the ultraRendu can still be powered by your favorite power supply because it shares the same power specification as the original. The ultraRendu remains as an Ethernet input and USB Audio output, but all the connectors are now located on the rear of the unit for easy cable routing. The ultraRendu utilizes a new proprietary printed circuit board with only the essential components and some updates to match its ultra designation. The best way to connect the ultraRendu to a USB device is via your favorite USB cable. The ultraRendu is easy to configure, accepts streams from various sources, and includes our new operating system Sonicorbiter 2.5.
SELECTABLE OUTPUT MODES - Sonicorbiter 2.5
Mode #1 - SqueezeLite Output - This output works with any Logitech Media Server and compatible controllers. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #2 - ShairPort Output - This is an AirPlay emulator that utilizes streams sent to it from a compatible source. This output supports true gapless playback of PCM.
Mode #3 - MPD/DLNA Output:
Mode #3a - DLNA Output - This output utilizes streams from UPNP/DLNA servers and controllers. This output can be configured as an OpenHome renderer. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #3b - MPD Output - This output is intended to work with a SMB mount. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #3c - Songcast Output - This output accepts streams from your computer running Linn Songcast. The application is in Beta form.
Mode #4 - HQ Player NAA Output - This output utilizes streams from Signalyst's HQ Player running on your computer. Digital signal processing is performed by HQ Player and then asynchronously streamed to the Network Audio Adapter (NAA) output. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #5 - RoonReady Output - This output utilizes streams from Roon. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #6 - Spotify Connect Output - This output can be controlled by your computer or tablet running the Spotify application. This application is based on librespot which is a an open source client library for Spotify. The application is in Beta form.
AVAILABILITY
MSRP 875 USD
www.sonore.us
vortecjr
Re: Sonore ultraRendu - Ethernet to USB source
« Reply #1 on: 26 Aug 2017, 05:25 pm »
News flash:
Audirvana Plus 3.1 was been officially released and Sonore products are among the first to receive the "Works With Audirvana +" approval.
