Evaluating the HDMI upgrade paths for SP-3
0 Members and 1 Guest are viewing this topic. Read 6528 times.
WillyP
Re: Evaluating the HDMI upgrade paths for SP-3
« Reply #20 on: 11 Sep 2017, 09:09 pm »
Does the latest version of the SP-3 get a new front, with numbers 1 -7?
And a bit of-topic, do you also have good news about the 9B3 power amplifier?
Willy
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #21 on: 11 Sep 2017, 09:11 pm »
Willy
I am not sure how Stan is handling that - will ask.
The 9B3 is still being worked on so I have high hopes it will be out this winter.
james
Grit
  • - Garrett
« Reply #22 on: 11 Sep 2017, 10:41 pm »
I know it's not a vote, but I would LOVE a new front. I'm sure this seems silly, but I'd prefer if the inputs were not named.  Instead of "DVD", CBL/SAT", I'd prefer "AES/BEU 1", "SPDIF 1", "BAL 1", etc. Or if they're all assignable, just "Input 1", etc.
WillyP
« Reply #23 on: 16 Sep 2017, 07:43 am »
Hi
I have a new version of the SP3 at home this weekend with the new 2.2 HDMI board and the new USB high resolution board - all seems to work well.
We should have units available shortly.
james
Hi James,
When will the SP3 with the new 2.2 HDMI board available?
Kind regards,
Willy
« Reply #24 on: 16 Sep 2017, 10:17 am »
Hi James,
Kind regards,
Willy
It should be any time now.
james
WillyP
« Reply #25 on: 20 Sep 2017, 11:48 am »
Hi James,
If my dealer orders the SP-3 now, will it be the new version with updated USB and HDMI board?
Is the delivery time the same for silver or black versions of Bryston, also for the BDP-3 and DAC-2 or -3?
Kind regards,
Willy
Nick77
« Reply #26 on: 20 Sep 2017, 12:06 pm »
I listen to DSD through HDMI and have a question about quality HDMI cable for audio reproduction.
What quality HDMI cables are you guys using for best sound?
WillyP
« Reply #27 on: 22 Sep 2017, 03:48 am »
Hi James,
Kind regards,
Willy
Hi James,
Could you please answer my questions?
Willy
« Reply #28 on: 22 Sep 2017, 10:45 am »
Hi James,
Kind regards,
Willy
Hi Willy
Sorry I just saw this.
Yes we are producing the new versions of the SP3 now - just to make sure though when the dealer orders make sure he says you want the new boards.
Yes the delivery time on most products is about 2 weeks from order.
james
Grit
  • - Garrett
« Reply #29 on: 22 Sep 2017, 11:09 am »
Ooooh! And what about upgrades? Options, ETA & prices?
And what'd you do with the back panel (old panels had 8 HDMI vs 7 now, correct?)
« Reply #30 on: 22 Sep 2017, 02:56 pm »
Yes you can email Mike about the upgrade options - mpickett@bryston.com
I believe we are using new back panels with the upgrade.
james
BSMSPEMBA
« Reply #31 on: 10 Oct 2017, 01:19 pm »
James,
A couple questions, please.  Does the new HSR72Q board support Dolby Vision?  Regarding the upgrade, has the cost been determined and will a new front panel be installed, since there will only be 7 inputs?
Thank you
BrystonFan
« Reply #32 on: 15 Oct 2017, 08:28 pm »
Hi James,
Can we start sending in our SP3 via your licensed dealers to Bryston for the 4K upgrade?
What is the turnaround time like?
I have to prepare myself to be without my baby.  :cry:
« Reply #33 on: 16 Oct 2017, 12:31 am »
Hi James,
Hi
Please email Mike on this as we are doing a few now and he will know the schedule.
gbaby
« Reply #34 on: 16 Oct 2017, 02:51 pm »
James,
Thank you
When you start asking for new panels you ask for increased cost. I would forgo new panel if it will keep cost down.
BSMSPEMBA
« Reply #35 on: 16 Oct 2017, 05:03 pm »
I was thinking about it.  There is no compelling reason to change the front panel.  Although the HDMI inputs will decrease from 8 to 7, the total number of inputs will stay the same.  If they remove HDMI from Bal-2, the only thing that will be "mislabeled" is the "8" below the Bal-2 button. However, the input will remain active as either analogue or digital (opt or coax).
Gbaby, I agree with you, that would not be worth incurring additional cost.
