DAC-9 and HPA-9
0 Members and 1 Guest are viewing this topic. Read 945 times.
Bloom1966
DAC-9 and HPA-9
« on: 17 Jul 2017, 09:29 am »
Good day to you all,
May be this topic is already on this site.
But I have a short question.
On the NuPrime website I couldn't find the answer.
I already own a STA-9. as pre-amp I would like to buy the DAC-9.
How can I integrate a HPA-9 in the future?
Can I still use the remote of the DAC for volume control?
Can I use the phono-section of the HPA (as a source) and still use the DAC as main pre-amp?
There's no manual of the HPA-9 on the site and the manual of the DAC does not refer to the HPA.
Can any one help me out?
Thanks and regards
Henk
rustydoglim
    • www.nuprimeaudio.com
Re: DAC-9 and HPA-9
« Reply #1 on: 17 Jul 2017, 06:05 pm »
Normally you connect the DAC-9 RCA outputs to HPA-9, and then HPA-9 RCA outputs to STA-9.
You can listen from your speakers or headphones by fixing HPA-9 volume and use DAC-9 to adjust.
The issue here is when using the turntable as source and still want to use the DAC-9 remote volume control.
This connection should work but I need to check with engineering if it will create ground loop noise:
- Connect DAC-9 XLR outputs to STA-9
- connect DAC-9 RCA outputs to HPA-9
----> connect HPA-9 RCA outputs to DAC-9 RCA inputs
So when source is phono input, you would fix HPA-9 volume (there is memory retention for each input) and set DAC-9 input select to analog.
Bloom1966
Re: DAC-9 and HPA-9
« Reply #2 on: 17 Jul 2017, 06:12 pm »
Thanks Jason, I hope tomorrow new stuff arrives at my local dealer.
