X-static vs some other similar kits
0 Members and 1 Guest are viewing this topic. Read 5375 times.
dlynch34
Re: X-static vs some other similar kits
« Reply #60 on: 23 Nov 2017, 02:25 pm »
thanks for all the help... these things sounds incredible!!  I just sold my Magnepan 3.7i due to moving into a smaller place and I am more than happy with these replacing them!!
dlynch34
« Reply #61 on: 26 Nov 2017, 03:29 pm »
how much toe-in do you all do with your set up?
Danny Richie
    • http://www.gr-research.com
« Reply #62 on: 28 Nov 2017, 09:16 pm »
That depends on the room and seating position. Move them around and hear what works best for you.
dlynch34
« Reply #63 on: 30 Nov 2017, 01:58 am »
thanks been doing that think I have them dialed in.  I was wondering if anyone has compared the x-statik to the ob-5 and ob-7?
